XIicPs_LookupConfig Failed error at init
Hello.
every time I am powering my board; I am getting this message through the UART:
Starting System Controller...
020
how can i solve this problem? maybe a hard reset or restoring to factory defaults?
Thank you.
回复: XIicPs_LookupConfig Failed error at init
you can check XIicPs_LookupConfig function which is in your bsp library.
The lookupconfig function is just get the IIC hardware information.
so it must be something mismatch.
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
I will describe my problem in more details:
I opened SCUI.exe in order to set VADJ to 1.8 V .
Under FMC, set VADJ, boot-up tab, I checked the box  of "set VADJ to 1.8V" . (by mistake ran inifinate times)
I stopped the action, and from this moment on, i could not connect at all.
Now, every command I am trying to do through SCUI.exe GUI, is  returning: "Error while Running "<command name>". a timeout occured".
I rebooted the board and the problem continues. I didnt do any modification on the lookupconfig function, or the bsp library.
Thank You.
I didnt get any reply yet, can someone respond please?
