Anonymous
Not applicable
XM105 Debug Card 3D/Step model
Greetings.
I'm creating a board the will be mating to the XM105 Debug card. I've looked around and it seems 3D/Step models are not directly available. I tried aswell to import some of the design files available into Altium Designer but only schematics appeared to be contained there.
Is it possible to get a 3D step file for the XM105 Debug card for Artix 7 ?
Best regards
Re: XM105 Debug Card 3D/Step model
there are no 3D (.step) files available for FMC or carrier cards, however you can use Allegro BRD files (both source and pdf are provided) to build your 3D model if needed.
