XM105 - ZC702/ZCU102 Compatibility.
Is XM105 compatible with ZC702 and ZCU102 board?
The Base Board Support column for XM105 in the Xilinx FMC cards link shows a generic list and the user guide seems to be very old one to refer to.
Can any one  confirm on this compatibility (with a suitable evidence if available)?
Thanks and Regards,
Ajay Kumar
Re: XM105 - ZC702/ZCU102 Compatibility.
Yes we do support this for both the boards.
Check the respective board user guide for the requirements and also we have added the list of FMC card with board support here.
Checkout this link (Look for XM105):-
https://www.xilinx.com/products/boards-and-kits/fmc-cards.html#interfaceperipherals
https://www.xilinx.com/support/answers/63567.html
Here are the interface design test AR where XM105 is referred:-
https://www.xilinx.com/support/answers/54134.html
https://www.xilinx.com/support/answers/69244.html
Harshit
Harshit
Thank you for the confirmation Harshit.
