Observer kranthi018
Xilinx Platform cable USB-2 not detected through vivado, when trying to program Zed board
We are trying to connect the Xilinx platform cable USB to the Zed board, Through vivado, JTAG chain initialized and shown TCK pin default frequency as 6MHZ, but device is not detected , not shown any ID.
We found in the Device Manager but found no device found , we set the configuration settings "0000" that is standard JTAG mode, and measured the voltages across TDI,TDO, TMS, TCK  all are <=3.3V,
We captured the Signals in the Oscilloscopes and here by attaching all the waveforms and measured voltages across the pins
Re: Xilinx Platform cable USB-2 not detected through vivado, when trying to program Zed board
Hi @kranthi018 ,
Which version of Vivado and ISE you are using? And also share the OS details.
Since ZedBoard Documents are not availble with us. I can't comment more on Board hardware.
Since you are getting "ERROR: [Labtools 27-2269] No devices detected on target " Message in Tcl Console of vivado, Probable reasons for failure are:
>> Cable driver issue : You can reinstall Platform Cable II by referring this AR#54381  and if you are JTAG, then you can try reinstalling JTAG Driver by referring this AR#59128 .
>> If power issue is there in your ZedBoard, then Board may not get detected. You need to ensure that Board has no power issue.
>> Ensure you are using Supported Vivado/ISE for the FPGA present in Zed Board and also Supported OS for Corresponding Viivado/ISE version.
>> Ensure you have added Board files to Vivado.
>> Try reducing JTAG frequency to 3MHz and try detecting the Device.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
Deepak D N
