09-11-2019 08:33 AM
1) i copied .bin file to SD Card and i loaded to Evaluation. how to verify SD card is booting . My device configuration is SW = 00110,
i taken .bin file from https://www.xilinx.com/products/boards-and-kits/ek-z7-zc706-g.html#documentation
2) through JTAG configuration i tested BIST. all codes are programmed but i can't able see the output in terminal port.reference from xilinx
Actual output i received
Can any one please explain how to validate this design
09-13-2019 06:16 AM
Hi @kapildev
Are you using a proper serial COM terminal to check? You might want to try with tera term
09-24-2019 12:23 AM
09-24-2019 12:26 AM
Hi @kapildev
When you connect the board to you computer, do you see a new COM port? If yes, you might want to try to re-install the drivers:
https://www.xilinx.com/support/answers/33569.html
If you cannot see the COM port, are you sure you are using the UART connector?
09-24-2019 12:32 AM
Yes, I installed proper driver and i connected UART cable. In Serial monitor its showing port no and i connected that port
09-24-2019 12:36 AM
Hi @kapildev
Then your board might be dammaged
