metalgarri
Xilinx xc7z020 zynq UG873 example error
Hi everybody,
I started learning how to design with this platform some weeks ago and I have a problem:
I was following the file UG873, the example with cdma and axi hp slave port. I did everything step by step and nothing else and the design rule check in XPS doesn't show error. When I come back to Planahead and I try doing a synthesis I have this error:
First of all a message box window with a platgen.exe error (it says that I don't have dynamic link with libMdtSynthUtils.dll).
When I click ok button, in the tlc console I have this message:
"platgen -p xc7z020clg484-1 -lang vhdl -intstyle pa -toplevel no -ti system1_i -msg __xps/ise/xmsgprops.lst system1.mhs
make: *** [implementation/system1_processing_system7_0_wrapper.ngc] Error -1073741511
ERROR:EDK -
Error while running "make -f system1.make netlist".
ERROR: [Edk-166] (generate_target): Failed to execute XPS script. Please check for any errors reported by the XPS application in the console: [C:/Users/metalgarri/Desktop/tesi/ZYNQ/workspace/axi_cdma_example/axi_cdma_example.srcs/sources_1/edk/system1\__xps/pa\_system1_synth.tcl]"
The other examples on this tutorial work well.
My configuration is: Xilinx ise design suite 14.1 and Zedboard.
Can anyone please help me to solve this issue?
I really thank you
Carmine
htsvn
Try to open the system.xmp in the PlanAhead GUI and try to generate netlist in XPS environment. (EDK Tools --> GUI -->
Hardware --> Generate Netlist) This will identify the reason for the error you are seeing.
--HS
metalgarri
The error message in XPS is vague too...
But seems to work if I remove the CDMA ip instance from the design...
Could it be a license issue?
htsvn
That's strange. I dont think CDMA has a license. http://www.xilinx.com/products/intellectual-property/axi_central_dma.htm
Any other IP's connected to CDMA???? Post the log file, i will check.
--HS
metalgarri
ERROR:EDK:1592 - IPNAME:system1_axi_cdma_0_wrapper INSTANCE:axi_cdma_0 -
C:\Users\metalgarri\Desktop\tesi\ZYNQ\workspace\axi_cdma_example\axi_cdma_exa
mple.srcs\sources_1\edk\system1\system1.mhs line 154 - failed to move
mple.srcs\sources_1\edk\system1\implementation\axi_cdma_0_wrapper\axi_cdma_0_
wrapper.ucf to
mple.srcs\sources_1\edk\system1\implementation\system1_axi_cdma_0_wrapper.ncf
ERROR:EDK:440 - platgen failed with errors!
make: *** [implementation/system1_processing_system7_0_wrapper.ngc] Error 2
that is the error I receive from XPS after netlist generation...
and this is mhs file...
