Z-Turn 7Z020 Board Files
I am wondering where I can find board files for Z-Turn 7Z020 so that I can find the board in Vivado 2017.3 when creating the project.
The board files has to be in the following location but I do not know here to find the board files. Can someone share the board files if has already ?
C:\Program_Files\Xilinx_Vivado\Vivado\2017.3\data\boards\board_files
Participant sjg69
Re: Z-Turn 7Z020 Board Files
I guess these board files need Licence to use, they are not free to add in Vivado, right ?
no these files doesn't require separate license . Please make sure you have license for Vivado tools
Thanks and Regards
Balkrishan
Yes I have licence of Vivado and I able to Validate the Design having ZYNQ Processing System IP and AXI USB 2 IP but after I put the board files at the desired location I do not see Z-turn board when I create new project.  The Z-turn board is not there. I also restarted the Vivado software and log off computer but still not.
Hello, I have same problem with Board Files. I place Board Files (see attachment) at ~Vivado\2017.3\data\boards\board_files\zturn-7z020\2.1 but there is no ZTurn Board in the Vivado new project, any idea how to fix it ?
can you please check appendix A and follow the steps
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug895-vivado-system-level-design-entry.pdf
Thanks and Regards
Balkrishan
Hi @joniengr081,
From where did you get these board files? The contents looks different than the other board files.
Arpan
