sbersin
ZC702 / 3.3V on VADJ possible ?
Hi all,
I want to use IOs of my Zynq (banks 34&35) as LVCMOS33. I configured them in my .ucf constraint file. I checked on board and these are stucked at 2.5V as VADJ rail is configured. I thought I could use the PMBus to configure and power-up the VADJ to 3.3V, but the only possible think seems to go down to 1.2/1.5/1.8v.
So is it possible to work in 3.3V ?
BR,
SB
austin
ug850,
Vadj ships with it set to 2.5v.  If you wish to set it differently, you will have to read the manual...
Austin Lesea
Principal Engineer
Xilinx San Jose
eljln
Dear experts,
Anyone has been able to communicate with the PMBUS in zc702 ?   I have been working hard on this using the manual/examples etc but I cannot get it to work even for reading.
I do as follows:
init and set the mux to the pmbus with:
ConfigPtr = XIicPs_LookupConfig(IIC_DEVICE_ID);
if (ConfigPtr == NULL) {
return XST_FAILURE;
Status = XIicPs_CfgInitialize(&IicInstance, ConfigPtr,
ConfigPtr->BaseAddress);
if (Status != XST_SUCCESS) {
return XST_FAILURE;
XIicPs_SetSClk(&IicInstance, IIC_SCLK_RATE)
WriteBuffer = 0x80;
Status = XIicPs_MasterSendPolled(&IicInstance, &WriteBuffer,1,
MuxIicAddr);
ok
then
I try to read vout (READ_VOUT) command after setting the address to 0x34 for the PM controller.
WriteBuffer[0] = (u8) list_of_commands[READ_VOUT];
while (XIicPs_BusIsBusy(&IicInstance));
Status = XIicPs_MasterSendPolled(&IicInstance, WriteBuffer,1,IIC_SLAVE_ADDR);
return XST_FAILURE;
Status = XIicPs_MasterRecvPolled(&IicInstance, ReadBuffer,
2,IIC_SLAVE_ADDR);
         printf("failure\n");
         Status = XIicPs_ReadReg(&IicInstance, XIICPS_SR_OFFSET);
         printf("The status is %x\n", Status);
         Status = XIicPs_ClearOptions(&IicInstance, XIICPS_REP_START_OPTION);
I think I must be missing some additional commands to be able to read ?
Thanks for any hints you can give me.
afarnet
eljln,
zc702 VADJ does support 3.3v. Here is a link of documentation below on how to setup VADJ.
Changing the code for the PMBus controllers is not recommended since it can affect the board functionality.
Could you open a webcase with Tech Support?
eljln
cannot see the link ...
afarnet
eljln
OK, I have access to that.
Basically, I am looking for a solution to read V, I values from the PMBUS directly through the IIC bus in the ZC702. It should be possible but something seems to be broken somewhere. I have raised a webcase to see if Xilinx has had more luck than me.
sylin
Dear All,
I still don't know how to adjust VADJ to 3.3V. Is it possible? How?
BR,
SYLin
amandaw
AR #51438 provides a step-by-step for changing the power levels on your boards.  Caveat emptor on raising the VADJ level to 3.3v, I recommend reviewing the schematics for any hardware incompatibilities.
