Observer saurabhnair
ZC702 CAN bus baudrate
I'm working on ZYNQ ZC702 board.
I'm trying to use the CAN bus interface for communication.
But I'm not able to understand how to find the clock frequency(PS_CLK) value and how to get the baudrate using BRP, SJW, TS1 and TS2 values.
Any help or guidance would be appreciated.
Re: ZC702 CAN bus baudrate
The below documents gives some useful information for debugging
http://www.xilinx.com/support/documentation/boards_and_kits/zc702_zvik/ug850-zc702-eval-bd.pdf
http://www.xilinx.com/support/documentation/boards_and_kits/zynq-7000/zc702_gsg/v3_0/UG926_Z7_ZC702_Eval_Kit.pdf
finally solved it.
The clock frequency is fixed at 33.33MHz. The internal PLL makes it 1000MHz.
Then in the slcr registers for CAN, modify the register accordingly, to get the desired CAN clock.
http://www.xilinx.com/support/answers/22656.htm
This site helped me setting the Baud rate and it also explains how the bits are used...
Hope it helps...
