gaosen1990
[ZC702] Vxworks6.9 Booting From an Secure Digital Card Failure !
i've followed the xapp1158 to run vxworks6.9 on my zc702.
Booting from an SD Card failure,but  successfully by using FTP.
here is the message from uart:
[VxWorks Boot]: @
boot device          : fs
unit number          : 0
processor number     : 0
file name            : /sd0:1/vxWorks
flags (f)            : 0x0
other (o)            : gem0
Loading... rcmd transfer failed
Error loading file: errno = 0x320001.
Host Name: bootHost
Target Name: vxTarget
User: target
Thanks in advance,
gaosen
gaosen1990
anyone can help♂me?
umamahe
As an initial step please verify as per the following AR http://www.xilinx.com/support/answers/47864.htm
