ZC702 fails at BIST test and not able to detect ETHERNET PHY
      I am newbie in working with FPGA  projects. I am trying to store data on the DDR  through the Ethernet interface.  but i am not even able to perform ping operation after executing the lwip xilinx driver.
      I am having problems with execution of BIST program on ZC702 board.The program hangs at detecting Ethernet PHY.  I have tried various solutions which are listed below  and also want to know whether can we consider that there is a hardware fault if the BIST program fails?
   1.Configured the drivers at kernel configuration menu for Ethernet and Edited the device tree file i.e system-user.dtsi  file in petalinux flow with below code . built the whole  project again.
&gem0 {
phy-handle = <&phy0>;
ps7_ethernet_0_mdio: mdio {
#address-cells = <1>;
#size-cells = <0>;
phy0: phy@7 {
device_type = "ethernet-phy";
reg = <7>;
  the output at  the console is given in first attachment.
2.
   I have tried to edit the memory address of Ethernet phy i.e e000b000  as mentioned  in this forum
https://forums.xilinx.com/t5/Embedded-Linux/Problem-with-u-boot-MDIO-not-finding-PHY-on-zc702/td-p/331137.
 and mii info command in u-boot  hangs after performing those editing. Output is provided in the second attachment.
 these are the changes  that i have done
> mm e000b000
e000b000: 00000000 ? 00000010
e000b004: 00080000 ? 000c0000
e000b008:  ? q
> mii info
This is the log file after booting the ZC702 board if that helps in finding the fault.
-Boot 2017.01 (Feb 16 2018 - 11:30:26 +0530)
Board: Xilinx Zynq
I2C:   ready
DRAM:  ECC disabled 1 GiB
MMC:   sdhci@e0100000: 0 (SD)
reading uboot.env
** Unable to read "uboot.env" from mmc0:1 **
Using default environment
In:    serial
Out:   serial
Err:   serial
Net:   ZYNQ GEM: e000b000, phyaddr 7, interface rgmii-id
PHY is not detected
GEM PHY init failed
No ethernet found.
U-BOOT for ethernet
Device: sdhci@e0100000
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: No
Capacity: 1.8 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading image.ub
3818084 bytes read in 334 ms (10.9 MiB/s)
   Using 'conf@2' configuration
   Verifying Hash Integrity ... OK
   Trying 'kernel@0' kernel subimage
     Description:  Linux Kernel
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x100000d4
     Data Size:    3802544 Bytes = 3.6 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0x00008000
     Entry Point:  0x00008000
     Hash algo:    sha1
     Hash value:   29768c97659ce238d3598ec1962899902254308a
   Trying 'fdt@0' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Data Start:   0x103a0778
     Data Size:    14246 Bytes = 13.9 KiB
     Architecture: ARM
     Hash algo:    sha1
     Hash value:   d3c938e1f971b780c8ccf89d59e0bb8f9e27b22a
   Booting using the fdt blob at 0x103a0778
mdio_register: non unique device name 'eth0'
   Loading Kernel Image ... OK
   Loading Device Tree to 07ff9000, end 07fff7a5 ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 4.9.0-xilinx-v2017.4 (xenoverze@xenoverze-Lenovo-G50-80) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP PREEMPT Fri Feb 16 11:03:19 IST 2018
OF: fdt:Machine model: xlnx,zynq-7000
bootconsole [earlycon0] enabled
cma: Reserved 16 MiB at 0x3f000000
Memory policy: Data cache writealloc
percpu: Embedded 14 pages/cpu @ef7d2000 s25932 r8192 d23220 u57344
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260608
Kernel command line: console=ttyPS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 1012868K/1048576K available (6144K kernel code, 200K rwdata, 1480K rodata, 1024K init, 229K bss, 19324K reserved, 16384K cma-reserved, 245760K highmem)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
    lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc0700000   (7136 kB)
      .init : 0xc0900000 - 0xc0a00000   (1024 kB)
      .data : 0xc0a00000 - 0xc0a323c0   ( 201 kB)
       .bss : 0xc0a323c0 - 0xc0a6ba58   ( 230 kB)
        Build-time adjustment of leaf fanout to 32.
        RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
efuse mapped to f0802000
slcr mapped to f0804000
L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
zynq_clock_init: clkc starts at f0804100
Zynq clock init
sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 4398046511103ns
clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x4ce07af025, max_idle_ns: 440795209040 ns
Switching to timer-based delay loop, resolution 3ns
clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
timer #0 at f080c000, irq=17
Calibrating delay loop (skipped), value calculated using timer frequency.. 666.66 BogoMIPS (lpj=3333333)
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
Setting up static identity map for 0x100000 - 0x100058
Brought up 2 CPUs
SMP: Total of 2 processors activated (1333.33 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
pinctrl core: initialized pinctrl subsystem
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor menu
zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0xf0880000
zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 27, base_baud = 3125000) is a xuartps
`▒▒k▒▒▒▒[ttyPS0] enabled
console [ttyPS0] enabled
bootconsole [earlycon0] disabled
vgaarb: loaded
SCSI subsystem initialized
media: Linux media interface: v0.10
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
EDAC MC: Ver: 3.0.0
FPGA manager framework
fpga-region fpga-full: FPGA Region probed
Advanced Linux Sound Architecture Driver Initialized.
clocksource: Switched to clocksource arm_global_timer
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
futex hash table entries: 512 (order: 3, 32768 bytes)
workingset: timestamp_bits=30 max_order=18 bucket_order=0
jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
bounce: pool size: 64 pages
io scheduler noop registered
dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.dmac:        DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
xdevcfg f8007000.devcfg: ioremap 0xf8007000 to f086d000
[drm] Initialized
brd: module loaded
loop: module loaded
m25p80 spi0.0: found n25q128a11, expected n25q512a
m25p80 spi0.0: n25q128a11 (16384 Kbytes)
4 ofpart partitions found on MTD device spi0.0
Creating 4 MTD partitions on "spi0.0":
0x000000000000-0x000000500000 : "boot"
0x000000500000-0x000000520000 : "bootenv"
0x000000520000-0x000000fa0000 : "kernel"
0x000000fa0000-0x000001000000 : "spare"
libphy: Fixed MDIO Bus: probed
libphy: mdio_driver_register: xgmiitorgmii
CAN device driver interface
libphy: MACB_mii_bus: probed
mdio_bus e000b000.etherne:07: mdio_device_register
macb e000b000.ethernet eth0: no PHY found
e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
sky2: driver version 1.30
ehci-pci: EHCI PCI platform driver
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
cdns-i2c e0004000.i2c: 400 kHz mmio e0004000 irq 24
cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer at f098b000 with timeout 10s
EDAC MC: ECC not enabled
Xilinx Zynq CpuIdle Driver started
mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci] using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
usbhid: USB HID core driver
NET: Registered protocol family 10
sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20161123 t)
can: netlink gateway (rev 20130117) max_hops=1
hctosys: unable to open rtc device (rtc0)
of_cfs_init
of_cfs_init: OK
ALSA device list:
  No soundcards found.
Waiting for root device /dev/mmcblk0p2...
mmc0: new high speed SD card at address e624
mmcblk0: mmc0:e624 SU02G 1.84 GiB
 mmcblk0: p1 p2
EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
EXT4-fs (mmcblk0p2): recovery complete
EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 179:2.
devtmpfs: mounted
Freeing unused kernel memory: 1024K (c0900000 - c0a00000)
random: fast init done
INIT: version 2.88 booting
mount: you must be root
grep: /proc/filesystems: No such file or directory
bootlogd: cannot allocate pseudo tty: No such file or directory
/etc/rcS.d/S37populate-volatile.sh: line 205: /proc/cmdline: No such file or directory
/etc/rcS.d/S38dmesg.sh: line 17: /var/log/dmesg: No such file or directory
hwclock: can't open '/dev/misc/rtc': No such file or directory
Fri Feb 16 05:54:08 UTC 2018
Starting internet superserver: inetd.
INIT: Entering runlevel: 5
Configuring network interfaces... /etc/rc5.d/S10dropbear: line 32: /proc/mounts: No such file or directory
Starting Dropbear SSH server: dropbear.
Starting syslogd/klogd: done
Feb 16 05:54:08 ethernet syslog.info syslogd started: BusyBox v1.24.1
Feb 16 05:54:08 ethernet user.notice kernel: klogd started: BusyBox v1.24.1 (2018-02-16 11:21:30 IST)
Feb 16 05:54:08 ethernet user.info kernel: Booting Linux on physical CPU 0x0
Feb 16 05:54:08 ethernet user.notice kernel: Linux version 4.9.0-xilinx-v2017.4 (xenoverze@xenoverze-Lenovo-G50-80) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP PREEMPT Fri Feb 16 11:03:19 IST 2018
Feb 16 05:54:08 ethernet user.info kernel: CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
Feb 16 05:54:08 ethernet user.info kernel: CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Feb 16 05:54:08 ethernet user.info kernel: OF: fdt:Machine model: xlnx,zynq-7000
Feb 16 05:54:08 ethernet user.info kernel: bootconsole [earlycon0] enabled
Feb 16 05:54:08 ethernet user.info kernel: cma: Reserved 16 MiB at 0x3f000000
Feb 16 05:54:08 ethernet user.info kernel: Memory policy: Data cache writealloc
Feb 16 05:54:08 ethernet user.debug kernel: On node 0 totalpages: 262144
Feb 16 05:54:08 ethernet user.debug kernel: free_area_init_node: node 0, pgdat c0a317c0, node_mem_map ef7f7000
Feb 16 05:54:08 ethernet user.debug kernel:   Normal zone: 1536 pages used for memmap
Feb 16 05:54:08 ethernet user.debug kernel:   Normal zone: 0 pages reserved
Feb 16 05:54:08 ethernet user.debug kernel:   Normal zone: 196608 pages, LIFO batch:31
Feb 16 05:54:08 ethernet user.debug kernel:   HighMem zone: 65536 pages, LIFO batch:15
Feb 16 05:54:08 ethernet user.info kernel: percpu: Embedded 14 pages/cpu @ef7d2000 s25932 r8192 d23220 u57344
Feb 16 05:54:08 ethernet user.debug kernel: pcpu-alloc: s25932 r8192 d23220 u57344 alloc=14*4096
Feb 16 05:54:08 ethernet user.debug kernel: pcpu-alloc: [0] 0 [0] 1
Feb 16 05:54:08 ethernet user.info kernel: Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260608
Feb 16 05:54:08 ethernet user.notice kernel: Kernel command line: console=ttyPS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait
Feb 16 05:54:08 ethernet user.info kernel: PID hash table entries: 4096 (order: 2, 16384 bytes)
Feb 16 05:54:08 ethernet user.info kernel: Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Feb 16 05:54:08 ethernet user.info kernel: Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Feb 16 05:54:08 ethernet user.info kernel: Memory: 1012868K/1048576K available (6144K kernel code, 200K rwdata, 1480K rodata, 1024K init, 229K bss, 19324K reserved, 16384K cma-reserved, 245760K highmem)
Feb 16 05:54:08 ethernet user.notice kernel: Virtual kernel memory layout:
Feb 16 05:54:08 ethernet user.notice kernel:     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Feb 16 05:54:08 ethernet user.notice kernel:     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
Feb 16 05:54:08 ethernet user.notice kernel:     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
Feb 16 05:54:08 ethernet user.notice kernel:     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
Feb 16 05:54:08 ethernet user.notice kernel:     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
Feb 16 05:54:08 ethernet user.notice kernel:     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
Feb 16 05:54:08 ethernet user.notice kernel:       .text : 0xc0008000 - 0xc0700000   (7136 kB)
Feb 16 05:54:08 ethernet user.notice kernel:       .init : 0xc0900000 - 0xc0a00000   (1024 kB)
Feb 16 05:54:08 ethernet user.notice kernel:       .data : 0xc0a00000 - 0xc0a323c0   ( 201 kB)
Feb 16 05:54:08 ethernet user.notice kernel:        .bss : 0xc0a323c0 - 0xc0a6ba58   ( 230 kB)
Feb 16 05:54:08 ethernet user.info kernel: Preemptible hierarchical RCU implementation.
Feb 16 05:54:08 ethernet user.info kernel:      Build-time adjustment of leaf fanout to 32.
Feb 16 05:54:08 ethernet user.info kernel:      RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
Feb 16 05:54:08 ethernet user.info kernel: RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
Feb 16 05:54:08 ethernet user.info kernel: NR_IRQS:16 nr_irqs:16 16
Feb 16 05:54:08 ethernet user.info kernel: efuse mapped to f0802000
Feb 16 05:54:08 ethernet user.info kernel: slcr mapped to f0804000
Feb 16 05:54:08 ethernet user.warn kernel: L2C: platform modifies aux control register: 0x72360000 ->Feb FebFebFeFebFebFebFebFebFeFeFebFebFebFebFeFebFebFeb FebFebFebFeb 1FeFFeFFeb 1FFFeFeFeb 1FFeFeFeb 1FeFFeFFeFeb 16 0FeFeFeFFeb 16FeFeFFeFFeb 16 FeFeFFeFeFeb 16FeFeFFeFeb 16 0FeFeFeFeStarting tcf-agent: OK
touch: /var/lock/subsys/tcf-agent: No such file or directory
PetaLinux 2017.4 ethernet /dev/ttyPS0
ethernet login:
3.
 I have tried the pre-built images of ZC702 for Ethernet interface which are given in the following link below. and the log file when i have used the command ifconfig -a it shows all interfaces but when i configure it with the command ifconfig  eth0 192.168.1.10 it shows error as
zynq> ifconfig eth0 192.168.1.10
xemacps e000b000.ethernet: eth0: no PHY found
xemacps e000b000.ethernet: XEMACPS mii bus mii_probe fail.
ifconfig: SIOCSIFFLAGS: No such device or address
http://www.wiki.xilinx.com/Zynq-7000+AP+SoC+Performance+%E2%80%93+Gigabit+Ethernet+achieving+the+best+performance
-Boot 2015.01 (May 05 2015 - 14:52:44)
Board:  Xilinx Zynq
I2C:   ready
MMC:   zynq_sdhci: 0
SF: Detected N25Q128A with page size 256 Bytes, erase size 64 KiB, total 16 MiB
In:    serial
Out:   serial
Err:   serial
Board:  Xilinx Zynq
Net:   Gem.e000b000
Device: zynq_sdhci
Manufacturer ID: 3
OEM: 5344
Rd Block Len: 512
SD version 3.0
High Capacity: No
Capacity: 1.8 GiB
Bus Width: 4-bit
reading uEnv.txt
** Unable to read file uEnv.txt **
Copying Linux from SD to RAM...
reading uImage
3453680 bytes read in 307 ms (10.7 MiB/s)
reading devicetree.dtb
10717 bytes read in 21 ms (498 KiB/s)
reading uramdisk.image.gz
5252253 bytes read in 466 ms (10.7 MiB/s)
## Booting kernel from Legacy Image at 02080000 ...
   Image Name:   Linux-3.18.0-xilinx-g1f5705755cc
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3453616 Bytes = 3.3 MiB
   Load Address: 00008000
   Entry Point:  00008000
   Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 04000000 ...
   Image Name:
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    5252189 Bytes = 5 MiB
   Load Address: 00800000
   Entry Point:  00800000
## Flattened Device Tree blob at 02000000
   Booting using the fdt blob at 0x2000000
   Loading Ramdisk to 1fafd000, end 1ffff45d ... OK
   Loading Device Tree to 1faf7000, end 1fafc9dc ... OK
Starting kernel ...
Linux version 3.18.0-xilinx-g1f5705755cc3 (sorenb@xsjsorenbubuntu) (gcc version 4.8.3 20140320 (prerelease) (Sourcery CodeBench Lite 2014.05-23) ) #1 SMP PREEMPT Fri May 1 16:04:50 PDT 2015
Machine model: Zynq ZC702 Development Board
PERCPU: Embedded 10 pages/cpu @7e7cf000 s8768 r8192 d24000 u40960
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260096
Kernel command line: console=ttyPS0,115200 root=/dev/ram rw earlyprintk
Memory: 1010880K/1048576K available (4673K kernel code, 241K rwdata, 1616K rodata, 212K init, 219K bss, 37696K reserved, 0K highmem)
    fixmap  : 0xffc00000 - 0xffe00000   (2048 kB)
    vmalloc : 0x80800000 - 0xff000000   (2024 MB)
    lowmem  : 0x40000000 - 0x80000000   (1024 MB)
    pkmap   : 0x3fe00000 - 0x40000000   (   2 MB)
    modules : 0x3f000000 - 0x3fe00000   (  14 MB)
      .text : 0x40008000 - 0x4062c8d8   (6291 kB)
      .init : 0x4062d000 - 0x40662000   ( 212 kB)
      .data : 0x40662000 - 0x4069e6e0   ( 242 kB)
       .bss : 0x4069e6e0 - 0x406d55f8   ( 220 kB)
        Dump stacks of tasks blocking RCU-preempt GP.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76360001
slcr mapped to 80804000
zynq_clock_init: clkc starts at 80804100
Zynq clock init
sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 3298534883328ns
timer #0 at 80806000, irq=43
Calibrating delay loop... 1332.01 BogoMIPS (lpj=6660096)
Setting up static identity map for 0x46a728 - 0x46a780
CPU1: Booted secondary processor
Brought up 2 CPUs
SMP: Total of 2 processors activated.
regulator-dummy: no parameters
cpuidle: using governor ladder
zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0x80880000
VCCPINT: 1000 mV
vgaarb: loaded
EDAC MC: Ver: 3.0.0
TCP: reno registered
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 5132K (5fafd000 - 60000000)
msgmni has been set to 2016
xuartps e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 82, base_baud = 3125000) is a xuartps
xdevcfg f8007000.devcfg: ioremap 0xf8007000 to 8086c000
[drm] Initialized drm 1.1.0 20060810
brd: module loaded
loop: module loaded
5 ofpart partitions found on MTD device spi0.0
Creating 5 MTD partitions on "spi0.0":
0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
0x000000100000-0x000000600000 : "qspi-linux"
0x000000600000-0x000000620000 : "qspi-device-tree"
0x000000620000-0x000000c00000 : "qspi-rootfs"
0x000000c00000-0x000001000000 : "qspi-bitstream"
e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
e1000e: Copyright(c) 1999 - 2014 Intel Corporation.
libphy: XEMACPS mii bus: probed
xemacps e000b000.ethernet: pdev->id -1, baseaddr 0xe000b000, irq 54
ULPI transceiver vendor/product ID 0x0424/0x0007
Found SMSC USB3320 ULPI transceiver.
ULPI integrity check: passed.
zynq-ehci zynq-ehci.0: Xilinx Zynq USB EHCI Host Controller
zynq-ehci zynq-ehci.0: new USB bus registered, assigned bus number 1
zynq-ehci zynq-ehci.0: irq 53, io mem 0x00000000
zynq-ehci zynq-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
cdns-i2c e0004000.i2c: 400 kHz mmio e0004000 irq 57
i2c i2c-0: Added multiplexed i2c bus 1
i2c i2c-0: Added multiplexed i2c bus 2
at24 3-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
i2c i2c-0: Added multiplexed i2c bus 3
i2c i2c-0: Added multiplexed i2c bus 4
rtc-pcf8563 5-0051: chip found, driver version 0.4.3
rtc-pcf8563 5-0051: rtc core: registered rtc-pcf8563 as rtc0
i2c i2c-0: Added multiplexed i2c bus 5
i2c i2c-0: Added multiplexed i2c bus 6
i2c i2c-0: Added multiplexed i2c bus 7
i2c i2c-0: Added multiplexed i2c bus 8
pca954x 0-0074: registered 8 multiplexed busses for I2C switch pca9548
ucd9200 8-0034: Device ID UCD9248-80|5.8.0.11400|091112
ucd9200 8-0034: 4 rails configured
ucd9200 8-0035: Device ID UCD9248-80|5.8.0.11400|091112
ucd9200 8-0035: 4 rails configured
ucd9200 8-0036: Device ID UCD9248-80|5.8.0.11400|091112
ucd9200 8-0036: 2 rails configured
zynq-edac f8006000.memory-controller: ecc not enabled
sdhci-arasan e0100000.sdhci: No vmmc regulator found
sdhci-arasan e0100000.sdhci: No vqmmc regulator found
si570 1-005d: registered, current frequency 148500000 Hz
TCP: cubic registered
can: broadcast manager protocol (rev 20120528 t)
input: gpio-keys as /devices/soc0/gpio-keys/input/input0
rtc-pcf8563 5-0051: setting system clock to 2017-12-15 13:24:57 UTC (1513344297)
ALSA device list:
▒RAMDISK: gzip image found at block 0 e624
 mmcblk0: p1 p2
VFS: Mounted root (ext2 filesystem) on device 1:0.
devtmpfs: mounted
Freeing unused kernel memory: 212K (4062d000 - 40662000)
Starting rcS...
++ Mounting filesystem
FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
++ Setting up mdev
++ Starting telnet daemon
++ Starting http daemon
++ Starting ftp daemon
++ Starting ssh daemon
random: sshd urandom read with 21 bits of entropy available
rcS Complete
zynq> ifconfig -a
can0      Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          NOARP  MTU:16  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:10
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:60
eth0      Link encap:Ethernet  HWaddr 00:0A:35:00:01:22
          BROADCAST MULTICAST  MTU:1500  Metric:1
          collisions:0 txqueuelen:1000
          Interrupt:54 Base address:0xb000
lo        Link encap:Local Loopback
          LOOPBACK  MTU:65536  Metric:1
          collisions:0 txqueuelen:0
zynq> ifconfig -a
          Interrupt:60
          inet addr:192.168.1.10  Bcast:192.168.1.255  Mask:255.255.255.0
Please provide me information about where i should do the changes, Thank you.
Tags (3)
Newbie hting1
Re: ZC702 fails at BIST test and not able to detect ETHERNET PHY
in 1, modifying the dts, would you try this format and may change the ethernet phy address if still not working.
phy0: phy@7 { // change from 0 to 9
			compatible = "marvell,88e1510";
			reg = <0x7>; // change from 0 to 9
			marvell,reg-init = <0x3 0x10 0xff00 0x1e 0x3 0x11 0xfff0 0xa>;
In terms of phy address, 0 works for my zedboard and 7 works for my ZC702. And this differs from the revision or type of boards.
To my knowledge, they changed. (ref. https://github.com/Xilinx/linux-xlnx/commit/9a3832f0ac6fa697d4c7798970ba14a3bfed5517 )
I run Android on top of these two boards. Hope this can help you!
 I have tried with this format and booted it through qemu  in petalinux. but still the problem persists. i have also tried all combinations from 0 to 9 in the format
    I have tried the format you have specified and also tried  all combinations from 0 to 9 ..still not able to detect the phy.
u-boot
as you can see in the above pic .im able to detect during u-boot ..when i booted through qemu
but not when i am booting kernel...i have activated all drivers. i dont know whats the problem.
kernel
please suggest if you know anything about it ..thank you.
