Newbie userlow
ZC702: how to open schematic design files
which design tool did they use for the zc702 board? I can open the board file with Allegro PCB Editor but dont know how to open the schematik. Im usually using Allegro Capture which is not working here.
Thx.
Advisor joelby
Advisor
Re: ZC702: how to open schematic design files
Looks like Mentor Graphics PADS, but I don't personally use it so I can't confirm this.
The schematic tool is DxDesigner.
I have DxDesign PADS 9.4.1 but the schematic do not open, this is the error :
00:00:00 Starting Migration
00:00:00 Project configuration files are being read...
00:00:00 CDB flow is not used. Migrate as NETLIST flow...
Some user-specific settings have not been maintained during migration. See Migration.log if you want to know details.
00:00:01 Generating WIR files...
Started C:\MentorGraphics\9.4PADS\SDD_HOME\wv\win32\bin\check.exe -s zc702.1
Checking Block schematics:zc702, Sheet 1 ...
0 errors and 0 warnings on schematic schematics:zc702.1.
Total errors - 0 and warnings - 0
Finished C:\MentorGraphics\9.4PADS\SDD_HOME\wv\win32\bin\check.exe
Started C:\MentorGraphics\9.4PADS\SDD_HOME\wv\win32\bin\check.exe -s zc702.10
Checking Block schematics:zc702, Sheet 10 ...
0 errors and 0 warnings on schematic schematics:zc702.10.
Started C:\MentorGraphics\9.4PADS\SDD_HOME\wv\win32\bin\check.exe -s zc702.11
Checking Block schematics:zc702, Sheet 11 ...
0 errors and 0 warnings on schematic schematics:zc702.11.
Started C:\MentorGraphics\9.4PADS\SDD_HOME\wv\win32\bin\check.exe -s zc702.7
Checking Block schematics:zc702, Sheet 7 ...
0 errors and 0 warnings on schematic schematics:zc702.7.
Started C:\MentorGraphics\9.4PADS\SDD_HOME\wv\win32\bin\check.exe -s zc702.8
Checking Block schematics:zc702, Sheet 8 ...
0 errors and 0 warnings on schematic schematics:zc702.8.
Started C:\MentorGraphics\9.4PADS\SDD_HOME\wv\win32\bin\check.exe -s zc702.9
Checking Block schematics:zc702, Sheet 9 ...
0 errors and 0 warnings on schematic schematics:zc702.9.
00:00:09 Generating WIR files: done
00:00:13 Migration stopped because schematics cannot be migrated to iCDB
In log file :
00:00:09 Adding block zc702.46
00:00:09 Adding block zc702.47
00:00:09 Adding block zc702.48
00:00:13 Error: Default configuration for zc702.1 cannot be created:
viewbase: Error 222: Error - Could not find WIR file HDR_2X5_ALT.1.
How open with this version of tools ?
Thanks very much.
secureasm
secureasm,
I believe the version of DxDesigner used is DxDesigner version ePD 2005.1
Then how to open the schematic ?
What is the specific version of PADs ?
Thanks very much.
secureasm
PADS is not the schematic entry tool that was used. DxDesigner is the schematic entry tool. I would suggest that you contact Mentor Graphics for additional support of their tools.
I'm sorry but DxDesign is included in PADs. I have DxDesign but if I open schematics with this versione I have the error that I already mentioned above.
Why Xilinx does not update their software ?
Visitor notabene
Do You know the version number of DXDesigner used for schematic entry?
The version of DxDesigner used with 7 Series and Zynq boards is DxDesigner EPD 2005.1
I was able to open the schematic with PADs 9.4.1.
This is a complete project : ZC702 DxDesign
Check Attachments ...
secureasm
Observer xiaoweihuacom
that is great!
what have you done to resolve this problem, I encountered the same error,  I used pads9.2, when import the project the same error was reported
I manually removed the connector from the file ZC702.21. Imported the project successfully. Reinserted the connector on page 21 of the draft (CAN Bus).
secureasm
thank you
secureasm,
but can you speak more detailed, how to remove the connector? just delete the file folder?
Hi xiaoweihuacom,
this is a steps that I have used :
(1) Download and decompress "zc702_Schematic_Source_rdf0174_rev1_0.zip"
(2) Enter in directory ".\zc702_Schematic_Source_rdf0174_rev1_0\wir\"
(3) Open with text editor the file "zc702.21"
(4) Search "hdr_2x5_alt", you found first occurrence on line 120
(5) Select and delete all line from 120 to 149
(6) Save file
(7) Open normally with your version of DxDesgin and wait conversion
(8) Once the conversion end, open "zc702.21" on Board Sheet tree
(9) Add new part "hdr_2x5_alt" and place on schematics as "ZC702 EVALUATION PLATFORM HW-Z7-ZC702.pdf"
Nothing more ...
secureasm
Visitor cddc
hello,I meet the same problems too.It takes me a lot of time to open the schematic files.
I had tried mentor graphics EE2004,mentor graphics expediton EEP2007.2, mentor graphics expediton EEP2007.9.4,but all failed .The softwares all contain DxDesigner , but their filename extension that creat by DxDesigner are 'XXXX.prj' rather than 'XXXX.dproj' .
So ,wich software should I use to open the files? Or which verson of the mentor graphics should I use?
 The  files I try to open is from the website: ZC702 Schematics Source Files (Rev 1.0)
http://www.xilinx.com/support/documentation/zc702_14-3.htm
I suggest that Xlinx attatches the imformation about software  that used to creat the files about the documentations when Xilinx releases  source files .
cddc,
(Xilinx Answer 42901): http://www.xilinx.com/support/answers/42901.htm should help you here
Visitor cddc
thank you
secureasm,as he said in message 11.
I can open his files with Mentor Graphics EE7.9.4 without any error.
Newbie pnefos
Would you have this in Orcad dsn format?
Actually, all I am looking for is the Zynq7020 484 device so that's an OLB library or even if you have in orcad, just a right click copy to new schematic with the ZYNC part on it.
This would save some part symbol development, maybe 3 days of creation and checking.
Patrick
