ZC706 Flash error
I have a ZC706 board which I am trying to do some sanity checks on. I seem to have an issue programming QSPI Flash. I have tried the zc706 pcie example and the zc706_restore_flash example designs. For both these xilinx provided designs, run the "program_dual_qspi.bat" batch file on my windows machine, and get the following error message:
C:\zc706_restore_flash>call C:\Xilinx\SDK\2018.3\bin\program_flash -f C:\zc706_r
estore_flash\BOOT.mcs -offset 0 -flash_type qspi_dual_parallel
****** Xilinx Program Flash
****** Program Flash v2018.3 (64-bit)
**** SW Build 2405991 on Thu Dec 6 23:38:27 MST 2018
** Copyright 1986-2018 Xilinx, Inc. All Rights Reserved.
WARNING: Failed to connect to hw_server at TCP:localhost:3121
Attempting to launch hw_server at TCP:localhost:3121
Connected to hw_server @ TCP:localhost:3121
Available targets and devices:
Target 0 : jsn-JTAG-SMT2-210251A5333A
Device 0: jsn-JTAG-SMT2-210251A5333A-23731093-0
Retrieving Flash info...
Initialization done, programming the memory
ERROR: Flash Operation Failed
Press any key to continue . . .
I have tried using the Platform USB cable with SW 4 settings "10" and digilent USB-to-JTAG cable with SW4 settings "01". In both cases, the cable detection and device detection happens. Though I am not sure if the JTAG scan should see more than 1 device.
The SW11 settings are set for JTAG boot. I am desperate to get past this problem since its been going on for a bit and I can't seem to get the service access portal to connect me to a dedicated engineer.
Chintan
Re: ZC706 Flash error
Hello @chintan_tag
can you manually try programming the MCS file provided along with the flash restoration design ?
The batch file you are running should eventually call the 2015.4 version of VIVADO hardware manager which can cause this issue.
Thank you
