ZC706 INIT LED remains RED
I am using Zc706 board when I power on the board INIT led remains red only.
Setting: SW4-01
SW11 : 00000
i tried BIST application and Restoring Application but in both it gives error "UNABLE TO DETECT JTAG CHAIN".
I have tried these programs some days ago and they worked that time. But today i am having this issue.
I don't know weather it is a hardware problem or softaware.
Do we have solution of it ?
Re: ZC706 INIT LED remains RED
What is the cable being used? Is it a USB Type-A to Micro-B cable or a JTAG platform Usb cable?
SW4 needs to be set to 01 if using the USB Type-A to Micro-B cable provided with the kit, or 10 if using the Platform Cable USB (II) JTAG cable.
Are you able to see other LEDS status as Green during power-ON?
DS2 is red all other are green.
I have check this file already but not able to deduct why ds2 is remaining red all the time.
Visitor tejasdangi
I am having same problem...
Scholar sampatd
Check if the AR below gives you some pointers:
http://www.xilinx.com/support/answers/54013.html
I refer this link and have done all the settings as shown. But it didn't work for me.
Please give any other solution if possible.
Can you keep the mode pins to JTAG mode and tell if INIT LED is still RED?
We have tried to program using JTAG cable and PLATFORM USB CABLE II too.
Both times we have set selected correct mode.
But still it is not working.
Suddenly INIT LED has start toggeling at random time.
Visitor dcsergio
I have the same situation and I made the same steps you all described above.
My board is locked on INIT status after a power-down while programming FPGA.
How can I bring the board back  to a "fresh" status?
even we are facing same problem on Zync706 board
Any solution of it??
Visitor dcsergio
Our solution was to substitute the board. :-)
