ZC706 - Power Management - set VADJ through TI Fusion permanent?
Hello everyone,
I am currently trying to get the VADJ to 1.8V for an ZC706 Eval Board (Standard is 2.5V).
Now I found out, that you can reprogram the UCD90120A through the PMBus-Interface. This happens either via sending PMBus-Commands yourself PL/PS-wise or using the Texas Instruments Fusion Digital Power graphical user interface.
Three quesions:
1) Once I programmed the UCD90120A either way, do the settings stay after power off and on?
2) I read somewhere that you can get the USB-to-GPIO Cable from TI for free when you have an Eval Board. Is that still true?
3) If so, where can I get it for free? On the TI page there is only the 75$ product available.
Thanks in advance.
Steffen
Re: ZC706 - Power Management - set VADJ through TI Fusion permanent?
Q1) Once I programmed the UCD90120A either way, do the settings stay after power off and on?
Yes
Q2) I read somewhere that you can get the USB-to-GPIO Cable from TI for free when you have an Eval Board. Is that still true?
Q3) If so, where can I get it for free? On the TI page there is only the 75$ product available.
The following Answer http://www.xilinx.com/support/answers/54022.html give details
You can specify evaluation board voucher number. I guess there is discount in price
Also the below AR's are having useful information:-
http://www.xilinx.com/support/answers/56811.html
http://www.xilinx.com/support/answers/53599.html
http://www.xilinx.com/support/answers/57452.html
Yes
