viitk99
ZC706 power requirements
I am planning to use Xilinx ZC706 with TI based ADC and DAC EVM boards ADS5463EVM and DAC3152EVM for my design. The data converters are 12-bit and I will be using the FMC-connector to connect the boards.
I wanted to know if the Zynq board ZC706 can drive the boards without a heat sink fan?
From where can I get a heat sink/heat sink fan for ZC706?
-VK
bpatil
@viitk99
I do not see requirement of heatsink for your requirement.
Still I will suggest you to check for 7 Series and Zynq®-7000 XPE and estimate power required for your design. Accordingly decide heatsink required or not for your design. For more information on XPE you can find out at UG440 (v2018.2)
Bhushan
Bhushan
viitk99
Thank you for the reply.
I will look into the documents.
-VK
