ZCU102 - ARM-A53 and R5 not visible on JTAG Chain
When connecting through xsdb using the Digilent cable the ARM cores are not visible to the debugger.
Is there special setup or DIP switch that needs to be set for this to work.
xsdb% connect
tcfchan#2
xsdb% targets
  1  PS TAP
     2  PMU
        3  MicroBlaze PMU (Running)
     4  PL
  5* DAP (DEVICEEN is '0')
xsdb%
Thanks in advance
Sandeep
Re: ZCU102 - ARM-A53 and R5 not visible on JTAG Chain
s,
Which release of Vivado are you using?  I beliueve it must be 2016.1 or later.
Austin Lesea
Principal Engineer
Xilinx San Jose
Yes Austin,
That is correct, I am actually using the "HEAD" build 2016.3  , if you have a patch I can request my
technical contact to send me an updated build.
Sandeep
clear register value @0xff180068
/sbin/devmem 0xff180068 32 0
then start xsdk
seems to be working for now
