Visitor pg_r
ZCU102 AXI Access From Top VHDL module
The wrapper generated from .bd shows external ports (going out of the FPGA).
I have a module created interfacing with PORT B of a Dual Port RAM (instantiated as an IP to the ram controller) and the other side is connected to Zynq PS (PORT A).
Now I want to bring some registers from my local module to the wrapper so that I can use the memory data with other VHDL modules, what's the best way to accomplish that?
 Please advise
Re: ZCU102 AXI Access From Top VHDL module
Hi pg_r,
Not sure what I fully understand your use case, but I would start by taking a look at UG1209:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug1209-embedded-design-tutorial.pdf
In particular, take a look at the Design Example 1. On page 135 it shows how to add AXI interfaces to your Block Diagram and create a wrapper with them.
Andres
