eduardoparra
ZCU102 Building the DTB
I am following the zcu102_2016_1.pdf from http://www.xilinx.com/support/answers/66249.html.
In the step Building the DTB there is a fallen link "Here, the DTS at the link here is used". It is important to follow the instructions of this link to build the DTB?? In that case i would like to access to that information.
I have continued with the next instruction :
linux-xlnx/scripts/dtc/dtc -I dts -O dtb -o linux_files/system.dtb linux_files/ zynqmp-zcu102-revB.dts
and i have no response, i dont know if its because not have been able to access to the previous link.
I would be very greatful if you could help explain what i am doing wrong or giving me more details about this step. Thank you
Anonymous
Not applicable
There is two flies used in this doc; the open source Linux (osl) and petalinux flow. You should use the petalinux flow.
You can get the dtb from the Xilinx wiki released images.
http://www.wiki.xilinx.com/Zynq+2016.1+Release
Anonymous
Not applicable
