ZCU102: Error while launching program: Memory write error at 0xF00. Instruction transfer timeout
Hey Guys,
i just unpacked a ZCU102 board and wanted to run an working design (tested on another ZCU102 board). I quickly noticed that i am not able to debug software: Error Launching Program - Memory write error at 0x0. Cannot read sctlr_el3.
Later i followed Xilinx AR# 72210, AR# 71961 and AR# 72113 to apply the Patch by replacing the FSBL files by files from "72113-files.zip" and followed the instructions (running FSBL first, and then my application, both with disabled "Run psu_init" as advised in AR# 72210).
Unfortunately, even this work flow didn't resolve my problem, SDK stops with the error message: Error while launching program: Memory write error at 0xF00. Instruction transfer timeout
My ZCU102 board is labeled with: 0432055-05-1911, Vivado/SDK Version 2018.3
What can i do to solve this??
