Visitor syedhabib
ZCU102 PL Based Ethernet
Hi All,
I am new to the world of Zynq. Previously I have worked on 1G ethernet for KCU105.
Is there any ZCU102 example that can help me implementing PL Based ethernet interface on ZCU102. I want to transmit and receive data using the SFP connector and  without involving the PS side.
I have seen XAPP1305 but that design is not what I want. I want to use only the PL side of FPGA in order to run ethernet interface. Kindly guide me to an example that can help me in setting up design that can receive ethernet data from GTH transceiver connected to SFP connector. If there is no complete example at least guide me to set of IPs that I will need to incorporate in order to run just the PL based ethernet
Re: ZCU102 PL Based Ethernet
check XAPP1306
https://www.xilinx.com/support/documentation/application_notes/xapp1306-ps-pl-ethernet-performance-lwip.pdf
Thanks and Regards
Balkrishan
