06-20-2018 01:39 AM - edited 06-20-2018 04:12 AM
Good morning everyone,
I saw other posts about this problem but none of the solutions stick to my problem.
I just receive a ZCU102 and I was trying to do the "Quick start guide". But I´m block at the step 2. Indeed I don't have the three green led for good power (I just have a red one on PS_ERR_OUT).
I did the switch configuration right but it's still not working. Do you have any ideas to solve my problem please ?
(which not included any re-programmig Maxim Power module ) Thanks !
06-20-2018 10:54 AM
Hello @rainbow_dash,
Please contact your distributor or channel through which you have purchased the board.
They will help you open the service request for the debugging.
Meanwhile please check if all the board settings are on default.
Please note we have seen cases where reprogramming the power controller has resolved such query.
The power controller GUI will help you track the specific rail and its conditions. There is a chance that onboard power controller has lost it's code or it has been corrupted.
Please try the SCUI utility provided by Xilinx to check the power rails current status. Please refer XTP433 from below link:
https://www.xilinx.com/search/support-keyword-search.html?searchKeywords=xtp433
Hope this helps.
Thank you.
06-21-2018 01:14 AM - edited 06-21-2018 01:15 AM
I already did it but they can't help me and said I need to ask to Xilinx directly because they don't have the expertise for.
08-13-2018 08:26 AM
Do you solved that? The same behaviour happened in my new ZCU102 board, and I don't know how to solve it. :/
baldrism
09-20-2018 01:12 PM
Hi @rainbow_dash,
1. Please go through the Debug Checklist of ZCU102, in AR#68386.
2.If board is getting detected through Vivado hardware manger, then perform Flash Restoration as mentioned in ZCU102 Restoring Flash Tutorial (2018.2) and provide results of this procedure. Please download required files from this link rdf0383-zcu102-restoring-flash-c-2018-2.zip. After this step still PS_ERR_OUT LED is RED, please go for next step mentioned below.
3. Please check PMU_Global error status register, what error is contains ?( regarding to PS_ERR_OUT signal).
If you carry out 3rd step please share the value present in ERROR STATUS 1 and ERROR STATUS 2 registers.
Thanks and Regarsd,
Deepak D N
Please reply or give Kudos or Mark it as an Accepted Solutions
01-13-2019 11:12 AM
I receive the ZCU102 board two weeks ago and have the same problem when I followed the instruction (https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842112/Zynq+UltraScale+MPSoC+Ubuntu+part+1+-+Running+the+Pre-Built+Ubuntu+Image+and+Power+Advantage+Tool). It is frustrating that Xilinux does not even bother to ship the board with a bootable SDK. Customers have to debug the same problem again and again. I am thinking to return the ZCU board because I wasted lots of time to be Xilinux's tester. Sorry, that is the way how Xilinux treats the customer.
10-01-2019 06:35 PM
