ZCU102 Rev 1.1 Fail to update firmware
I just get ZCU102 REV 1.1
I tried to update firmware, refer to XTP433 Doc., but I failed to.
Please refer to following log msg..
Is there anyone to help?
If you need more information, please let me know.
Info: SYS_CTLR v1.50 RESTORE test started...
Info: The test will take 0 hours, 01 minutes, and 23 seconds. 0:01:23
Info: This step started at: 2019-11-05 18:28:52
!! Press ESC to enter System Controller mode.
User has confirmed: "Turn ZCU102 Board Power Off.
Set mode switch SW6 to "0" (Up,Up,Up,Up)
Connect two jumpers across J164 as shown in XTP433
Turn ZCU102 Power On"
step finished
Info: This step started at: 2019-11-05 18:29:08
after 2000
catch { disconnect }
1
after 2000
connect -url tcp:127.0.0.1:3121
attempting to launch hw_server
****** Xilinx hw_server v2019.1
  **** Build date : May 24 2019 at 15:13:31
    ** Copyright 1986-2019 Xilinx, Inc. All Rights Reserved.
INFO: hw_server application started
INFO: Use Ctrl-C to exit hw_server application
INFO: To connect to this hw_server instance use url: TCP:127.0.0.1:3121
tcfchan#0
targets -set -filter {name =~"*APU*"}
rst -srst
after 3000
fpga -no-revision-check -file D:/ZYNQ/Doc/ZCU102/rdf0382-zcu102-system-controller-c-2019-1/zcu102_scui/flash_restore/tests/ZCU102/bitstream/boot_strap_loader.bit
initializing
  0%    0MB   0.0MB/s  ??:?? ETA
  4%    1MB   2.1MB/s  ??:?? ETA
  7%    1MB   1.9MB/s  ??:?? ETA
 11%    2MB   1.8MB/s  ??:?? ETA
 14%    3MB   1.8MB/s  ??:?? ETA
 17%    4MB   1.7MB/s  ??:?? ETA
 20%    5MB   1.7MB/s  00:11 ETA
 24%    6MB   1.7MB/s  00:11 ETA
 27%    6MB   1.7MB/s  00:10 ETA
 30%    7MB   1.7MB/s  00:10 ETA
 34%    8MB   1.7MB/s  00:09 ETA
 37%    9MB   1.7MB/s  00:09 ETA
 40%   10MB   1.7MB/s  00:08 ETA
 44%   11MB   1.7MB/s  00:08 ETA
 47%   12MB   1.7MB/s  00:07 ETA
 50%   12MB   1.7MB/s  00:07 ETA
 53%   13MB   1.7MB/s  00:07 ETA
 57%   14MB   1.7MB/s  00:06 ETA
 60%   15MB   1.7MB/s  00:05 ETA
 64%   16MB   1.7MB/s  00:05 ETA
 67%   17MB   1.7MB/s  00:04 ETA
 70%   17MB   1.7MB/s  00:04 ETA
 73%   18MB   1.7MB/s  00:03 ETA
 77%   19MB   1.7MB/s  00:03 ETA
 80%   20MB   1.7MB/s  00:02 ETA
 84%   21MB   1.7MB/s  00:02 ETA
 87%   22MB   1.7MB/s  00:01 ETA
 90%   22MB   1.7MB/s  00:01 ETA
 94%   23MB   1.7MB/s  00:00 ETA
 97%   24MB   1.7MB/s  00:00 ETA
100%   25MB   1.7MB/s  00:15
source D:/ZYNQ/Doc/ZCU102/rdf0382-zcu102-system-controller-c-2019-1/zcu102_scui/flash_restore/tests/ZCU102/tcl/bsl_psu_init.tcl
psu_init
after 1000
psu_ps_pl_isolation_removal
after 1000
psu_ps_pl_reset_config
targets -set -filter {name =~"*A53*0"}
rst -processor
dow D:/ZYNQ/Doc/ZCU102/rdf0382-zcu102-system-controller-c-2019-1/zcu102_scui/flash_restore/tests/ZCU102/elf/boot_strap_loader.elf
Downloading Program -- D:/ZYNQ/Doc/ZCU102/rdf0382-zcu102-system-controller-c-2019-1/zcu102_scui/flash_restore/tests/ZCU102/elf/boot_strap_loader.elf
	section, .text: 0x00000000 - 0x0001442f
	section, .init: 0x00014440 - 0x00014473
	section, .fini: 0x00014480 - 0x000144b3
	section, .note.gnu.build-id: 0x000144b4 - 0x000144d7
	section, .rodata: 0x000144d8 - 0x00014dcf
	section, .rodata1: 0x00014dd0 - 0x00014dff
	section, .sdata2: 0x00014e00 - 0x00014dff
	section, .sbss2: 0x00014e00 - 0x00014dff
	section, .data: 0x00014e00 - 0x00015fe7
	section, .data1: 0x00015fe8 - 0x00015fff
	section, .ctors: 0x00016000 - 0x00015fff
	section, .dtors: 0x00016000 - 0x00015fff
	section, .eh_frame: 0x00016000 - 0x00016003
	section, .mmu_tbl0: 0x00017000 - 0x0001700f
	section, .mmu_tbl1: 0x00018000 - 0x00019fff
	section, .mmu_tbl2: 0x0001a000 - 0x0001dfff
	section, .preinit_array: 0x0001e000 - 0x0001dfff
	section, .init_array: 0x0001e000 - 0x0001e007
	section, .fini_array: 0x0001e008 - 0x0001e047
	section, .sdata: 0x0001e048 - 0x0001e07f
	section, .sbss: 0x0001e080 - 0x0001e07f
	section, .tdata: 0x0001e080 - 0x0001e07f
	section, .tbss: 0x0001e080 - 0x0001e07f
	section, .bss: 0x0001e080 - 0x0011e2bf
	section, .heap: 0x0011e2c0 - 0x001262bf
	section, .stack: 0x001262c0 - 0x0012f2bf
 66%    0MB   0.2MB/s  ??:?? ETA
100%    0MB   0.2MB/s  00:00
Setting PC to Program Start Address 0x00000000
Successfully downloaded D:/ZYNQ/Doc/ZCU102/rdf0382-zcu102-system-controller-c-2019-1/zcu102_scui/flash_restore/tests/ZCU102/elf/boot_strap_loader.elf
con
step finished
Info: This step started at: 2019-11-05 18:29:40
Error: File could not be sent
Error: Found regular expression in step 3 of test 0 - "(.*)Error(.*)"
Error: Could not find regular expression in step 3 of test 0 - "(.*)File\s+sent\s+successfully"
Info: This step started at: 2019-11-05 18:30:00
Error: Stopped because step 3 failed in test 0
step finished
Error: Could not find regular expression in step 0 of test 0 - "(.*)MSP v1.50 I2C Bridge v1.50(.*)"
Info: Result for step 0: Fail
Info: Result for step 1: Pass
Info: Result for step 2: Pass
Info: Result for step 3: Fail
Info: The test took 0 hours, 00 minutes, and 54 seconds. 0:00:54
Re: ZCU102 Rev 1.1 Fail to update firmware
Hi @codbsdl ,
>> Are you using SCUI (version 2019.1)? And you have followed all the Jumper settings(J164) they have given in SCUI Firware update steps?
>> Also before perfoming SCUI Firmware update. Please go through this ZCU102 Debug Checklist  and confirm me till step 4 you are fine? If you have any issue in power then Firmware might not be possible.
Please share your Email ID which is registered with Xilinx. I will forward you the Firmware update steps through EZMove Software.
>> Please share the Firmware Date for your board. You can get that, like below using Tera term like below:
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
Deepak D N
Hi @codbsdl ,
Deepak D N
Deepak D N
I have the same problem. Identical printout except that I unpacked the zip file to C:\zcu102_scui.
Is there any solution? I have followed AR# 68386 through step 4 as suggested, and everything looks fine.
Brian S.
Hello @bschroeder ,
Can you please confirm what exact version of your Silicon labs driver is in your case, as we have a known issue which is described here:
https://www.xilinx.com/support/answers/69258.html
We've been tracking this issue for a while, and what we've found so far is that the newest version of the Silicon labs driver (6.7.6) does not appear work correctly with the BIT.  There is active development looking into the root cause but for now if you are looking to get the BIT up and running, you might need to install an older version of the Si Labs Driver.
You can check which version of the driver is installed by opening the Windows device manager and right clicking on one of the virtual COM ports, then selecting the "Driver" tab.  My guess is that the latest version was installed by default.
If you find that you have e.g. 6.7.6 installed, you might want to try installing an older version from the Si Labs website:
http://www.silabs.com/products/development-tools/software/usb-to-uart-bridge-vcp-drivers
Once done, please try updating the System Controller Firmware once again and then see if you are seeing a better outcome this time or not?
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
That fixed it. Thanks for the quick response.
BTW, I am running win10, and the driver was 10.1.8 from the CP210x_Universal_Windows_Driver. It is now 6.7 and the firmware update installed per xtp433.
Brian S.
