cdu
ZCU102: device not being recognized via JTAG
Error Message: can't read IR length
Platform: ZCU102
JTAG cable connection: tried both Digilent and Platform USB II, failed with same error message.
Chipscope version: ISE 14.7 with ISE ILA core inserted as a netlist
watari
Hi @cdu
Because ISE 14.7 doesn't have bsd file for ZCU102, it can't detect it.
There are two core on ZynqMPSoC and control command is a little different other devices.
So, you must use supported tools, like Vivado or Vivado lab tool.
Best regards,
watari
Hi @cdu
Best regards,
