ZCU104 Built in test
After step 4 (built-in self test) of the quick start guide for the ZCU104,
(https://www.xilinx.com/support/documentation/boards_and_kits/zcu104/xtp482-zcu104-quickstart.pdf)
The serial console brings up the following options
Choose Feature to Test:
1: UART Test
2: LED Test
3: IIC Test
5: TIMER/SCUGIC Test
6: CAN Bus Test
7: SWITCH Test
8: PS DDR4 External Memory Test
9: DDR4 External Memory Test
A: BRAM Internal Memory Test
B: BUTTON Test
C: Clocking Test
D: PMOD Test
G: System Monitor Test
H: ETHERNET Loopback Test
0: Exit
Some of these tests are failing or hanging.  Are they all expected to pass?
Re: ZCU104 Built in test
Hi @sioan ,
Basically for BIST Test, UART Cable is not neccessary. You need only board to perform BIST Test.
I belive you are connecting UART Cable and seing some Tests running in terminal, while you execute BIST Test. If that is the case, Xilinx will not comment on those, because Xilinx has not tested that part.
Hope you understand.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
Hi @sioan ,
While Perfoming BIST Test, UART terminal step will not be there.
In step 4 of XTP482, you should observe below LED's glowing :
If the above LED's are not glowing. Ensure there is no issue in First three steps of XTP482. If you are facing any issues in First three steps, let me know.
If first three steps are fine, and still if you are failing in Step4, then you need ot perform Flash Restoration (Download related Files )and again perform BIST Test(XTP482). After performing Flash restortion, if still BIST Test fails, please File a Devsys RMA Case to Xilinx to get your board replaced.
Deepak D N
Hi Deepak,
Thank you for the quick reply.  Your instructions are correct.  After they are completed, more tests can be observed in the UART terminal.
Are those implemented and working, or are they legacy from a different board?
Best,
Sioan
Hi @sioan ,
Deepak D N
