[ZCU104] Where to find board serial number?
Problem: I am unable to locate the serial number associated with my ZCU104 board.
Description: I am working through XTP498 "ZCU104 Board Interface Test" and on slide 9 (image below) I am told to run BIT.exe and then enter the board's serial number and MAC address.
I am able to find the MAC address because is it printed on my board. However, I cannot find the serial number any where on the board, on the box it was sent in, or in the quick start guide. There is a "Whizzy systems" sticker with a serial number but is not of the same length of format as that seen in the screenshot above. I have attached a picture below of the region of my ZCU104 board that shows the mac address. Maybe I am missing something here? Could it be a portion of the top number?
Thank You,
Mark
Re: [ZCU104] Where to find board serial number?
Your board serial number is 8955028681818-89190 where it says S/N.
Thanks a lot, was pretty confused.
Hi @hj ,
Where can I find this tool to search serial number from MAC address. Board is ZCU102.
Serial number of my board is lost. I only have information about Mac address is:
00:0A:35:04:C3:04 and whizzsystems.com : 0432055-04-1828
Thanks and brgs
