ZCU104 and Bumblebee2(FireWire)
We want to use  ZCU102 or ZCU104 (base Zynq board) for machine vision. We have the stereo camera "Bumblebee2" (FireWire). Is it possible to use ZCU102 or ZCU104 together with stereo camera "Bumblebee2"?
Re: ZCU104 and Bumblebee2(FireWire)
Hi artjoke@inbox.lv ,
The ZCU104 and ZCU102 do not have a firewire connector.
Also, Xilinx does not have an IP to receive firewire so you would also have to implement your own one.
If you need to use a stereo camera, you might want to use a USB camera as the ZED camera
Florent
Florent
Thank you for your answer!
Visitor ted1267
ZCU104 power supply
HI
Does anyone know where I can get extra power supply for my reference ZCU104 board?
thanks
ted
Re: ZCU104 power supply
Here are the Power Supplies for a few boards:
https://www.xilinx.com/support/answers/67507.html
You can use the same as ZCU102.
Andres
