Observer yjyoon37
ZCU106 board issue for enabling HDMI monitor
Dear Support Team,
We have confronted X-terminal issue after booting the image.
The symptom that we saw is that the Monitor does not respond via the HDMI port.
Please see below error message (2 crtical erros).
Would you help us to pass next step?
Current version of pixman: 0.34.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Tue Sep 24 06:04:16 2019
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
OK
root@zcu106_vcu_trd:~# The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning: Unsupported high keycode 372 for name <I372> ignored
> X11 cannot support keycodes above 255.
> This warning only shows for the first high keycode.
Errors from xkbcomp are not fatal to the X server
D-BUS per-session daemon address is: unix:abstract=/tmp/dbus-msAuo5P7pA,guid=82e31ae614ba5317e529472 95d89b1e2
Error: No calibratable devices found.
Failed to launch bus: Failed to execute child process ?/usr/bin? (Permission denied)matchbox: Cant f ind a keycode for keysym 269025056
matchbox: ignoring key shortcut XF86Calendar=!$contacts
matchbox: Cant find a keycode for keysym 2809
matchbox: ignoring key shortcut telephone=!$dates
matchbox: Cant find a keycode for keysym 269025050
matchbox: ignoring key shortcut XF86Start=!matchbox-remote -desktop
(matchbox-panel:2568): dbind-WARNING **: 06:04:19.983: Error retrieving accessibility bus address: o rg.a11y.Bus.Error: Failed to execute child process ?/usr/bin? (Permission denied)
(matchbox-desktop:2567): dbind-WARNING **: 06:04:19.983: Error retrieving accessibility bus address: org.a11y.Bus.Error: Failed to execute child process ?/usr/bin? (Permission denied)
Tags (2)
Re: ZCU106 board issue for enabling HDMI monitor
HI @yjyoon37
Is it a custom design or are you based on an example design?
Are you sure the HDMI TX IP is included in the design?
Can you share the boot log?
Florent
