ZCU106 rev1.0
I want to use ZCU106.
When I run the example program [Hello World], the program does not work.
What are the possible causes?
On the SDK screen, the display looks like Figure 1.
Here are the steps I took:
1.Launch [VIVADO 2019.1]
2.Select [Create Project]
3.Select [RTL_Project]
4.Select [Boards]-[Zynq UltraScale+ZCU 106 Evaluation Platform]
5.Select [Create Block Design]-add ZYNQ Ultra Scale+MPSoC
6.Conect [pl_clk0] to [maxihpm0_fpd_aclk] and [maxihpm1_fpd_aclk]
7.Add [Create HDL Wrapper]
8.Select [Generate Bitstream]
9.Select [Export Hardware]
10. Select [Launch SDK]
11. Select [New]-[Application Project]-[Hello World]
12. Conect PC to ZCU106
13. ZCU106 Power on
14. Select [Program FPGA]
15. Select [Debug AS]-[Lanch on Hardware]
Figure 1
Re: ZCU106 rev1.0
Hi florentw.
As a result of testing the memory setting of AR # 71961, it was confirmed that it operates normally.
Thank you very much.
Mentor watari
Mentor
Re: ZCU106 rev1.0
Hi ozeki_tomohiro-kge@corp.khi.co.jp
Would you refer the following URL, even if board is differet ?
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842048/ZU+Example+-+PM+Hello+World
Best regards
Re: ZCU106 rev1.0
I suspect that this issue you are seeing is related to the AR#71961.
Can you try to run the fsbl before running the hello world application?
Note: To create the FSBL, just create a new application using the FSBL template
Florent
Re: ZCU106 rev1.0
Hi watari
Thank you for your reply.
The type of board is different,but I will check it once.
Re: ZCU106 rev1.0
Hi florentw.
