ZCU106 voltage and temp measurement
I need to measure the voltage and temp from a ZCU106 board. I have known that the process need to use the sysmon IP core but do not know how to get it started. Can someone plz give me some advice?
Hi @rua
Would you run the following command on linux ?
awk '{ printf "APU Temp. = %.1f\n", ((($1 * 509.314)/65536.0)-280.23) }' < /sys/bus/iio/devices/iio:device0/in_temp0_ps_temp_raw
Best regards,
sry,but the platform I used is Vivado on Windowes
