ZCU111 DAC/ADC signal levels
I just started getting familiar with the ZCU111 board and I'm trying to figure out some information about the DAC/ADC interfaces:
What is the max DAC output current? (in UG1287 the introduction is saying 20 or 32mA, but I didn't see it mentioned later on)
What is the ADC input voltage range?
Are the DAC/ADC 50 ohm terminated?
Any advice on where I can find this information is greatly appreciated.
Thanks for your support in advance!
Tags (4)
Re: ZCU111 DAC/ADC signal levels
Hi Tamas,
I believe you can find all that information in the DC and AC Datasheet:
https://www.xilinx.com/support/documentation/data_sheets/ds926-zynq-ultrascale-plus-rfsoc.pdf
Here is the link to the RFSoC Documentation page:
https://www.xilinx.com/products/silicon-devices/soc/rfsoc.html#documentation
Andres
Hi Tamas,
Andres
Many thanks Andres!
