Visitor jhm1
ZCU111 Files not using petalinux
Hello
Just out of curiousity, would it be possible to generate the boot.bin file from Windows for the ZCU111 not using a Linux enviroment, or is it totally neccessary ?
Re: ZCU111 Files not using petalinux
Hello @jhm1
In general, you can create a boot.bin file using SDK but not for ZCU111 TRD files.
Most of the drivers are in github repositories and they are intended to work with petalinux only.
Thank you
Hello @jhm1
Thank you
Visitor jhm1
Thank you very much for the answer.
