ZCU111 Main Power connector
I have a RFSoC ZCU111 in the office, I don't have physical access to it and need to order a power cable to enable remote power control.
Does it have a main connector into the Transformer of a IEC C5 (Clover leaf) or IEC C15 (Kettle)
Tim
Re: ZCU111 Main Power connector
Hello @tmonaghan84 ,
Based on WhatsInside: https://www.xilinx.com/products/boards-and-kits/zcu111.html#whatsInside
You can see this picture (which isn't that clear):
I personally don't have ZCU111 available right now, however from the boards i have, we have this:
I strongly believe the same is for ZCU111, so IEC C15 (Kettle)
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Bingo thanks
I think IIRC
The ZCU104 has a clover leaf connector on the psu as the output of the transformer was lower (12V @ 4A)
The ZCU111 as you mention has a kettle connector and a higher output (12V @ 5A)
I've confirmed with the colleague who has the ZCU111 right now and here is the confirmation of the power connector of this board:
I believe you just need it to have 12v out and 5A
Hope this helps.
Kind Regards,
Anatoli Curran,
