ZCU111 QSPI Xilisf Settings
I am developing a project onboard the Xilinx ZCU111 RFSoC w/ qspi flash memory enabled. I have included the xilisf library when creating the bsp within xsdk. When generating the bsp, what values would I need to set the serial_flash_family & serial_flash_interface parameters to for this dev platform? The default is 1 and 1, but I am thinking I need 5 for serial_flash_family and 3 for serial_flash_interface. Can someone confirm? I am having issues with XSDK not running my code and wonder if this is the issue.
Thanks!
Hi @davidspinden ,
you are correct, the serial_flash_family & serial_flash_interface parameters for ZCU111 board should be 5 & 3.  Please check below:
Also, what is the issue that you are facing when you run your application. Please let me know if you are not able to run the code even after changing the parameters.
Best Regards,
Srikanth
Hi @davidspinden
Do you have an update to this?
Rohit
