tasker.j
ZCU111 RFSoc TRD - LVM File Version Error
I'm trying to load a LVM file that I created using lab view to the DAC for playback, but I'm getting a "File Version not compatible:" error when I load the file.  Screen shot of error is below and the lvm file I am loading is attached.  Thanks in advance.
Tags (4)
travisc
Are you using a converter, or just a direct export for the LVM file? Below is a guide on the LVM format and working with our TRD tool.
http://www.xilinx.com/support/answers/71687.htm
travisc
tasker.j
Hi @travisc,
Thanks for the reply but unfortunately I've already spent some time reviewing the provided link and have verified that the attached lvm file matches the settings in the provided document ("RF Data Converter Evaluation GUI file support".
I'm exporting the information directly from LabView in the LVM format. Any other ideas? What versioning is the GUI checking to get this error? Or is this just a general error with the file format?
Thanks again as I am still searching for a solution.
-Jim
tasker.j
HI again @travisc,
I re-read the link that you sent and the documents and found that the file had to have a Version of 1.2.0 in the special header section.  It now works as expected.  Thank you for your time.
