chyrie19
ZCU111 Standalone drivers for Read / write datas from/to converters
I am trying to understand, is it possible to read / write datas without Linux?
Reading the https://www.xilinx.com/support/documentation/boards_and_kits/zcu111/2019_1/ug1287-zcu111-rfsoc-eval-tool.pdf,
it does not seem. But I have difficulties to understand what is the interest to build standalone drivers if there is no way to read or write datas without linux..
Can someone explain me?
So if you have a window computer how is it possible to do?
Maybe @klumsde may help me ?
Is it possible to just change the Tool chain editor and make the "rfdc-data-write-example.c" work with the pre-built image for non-MTS design?
Thank you for your answer.
