ZCU111 - System Controller GUI doesn't work
I started using a ZCU111 board. First, it passed the built-in self-test. Then I tried out System Controller GUI. However the GUI software doesn't work on my Windows 10 PC. Board serial number was detected correctly in the pull-down menu. But the GUI doesn't really perform any functions by pushing buttons. The button is grayed out after pushing .
Looking at log file at C:\zcu111_bit\BoardUI\tests\ZCU111\logs, it seems like an internal error on the software.
ZCU111_*******.txt:
[TITLE : Fri, 21, Sep 2018 10:28:13] Board: ZCU111
[TITLE : Fri, 21, Sep 2018 10:28:13] Revision: B
[TITLE : Fri, 21, Sep 2018 10:28:13] Silicon: prod
[TITLE : Fri, 21, Sep 2018 10:28:13] Serial Number: ***** <-- Okay
[TITLE : Fri, 21, Sep 2018 10:28:13] MAC Address: 01:02:03:04:05:06
[TITLE : Fri, 21, Sep 2018 10:28:13] Working in directory: ZCU111
[TITLE : Fri, 21, Sep 2018 10:28:59] PRESSED: Get Version
[INFO : Fri, 21, Sep 2018 10:28:59] Starting step sysc
[ERROR : Fri, 21, Sep 2018 10:28:59] Exception in thread Thread-1:
[ERROR : Fri, 21, Sep 2018 10:28:59] Traceback (most recent call last):
[ERROR : Fri, 21, Sep 2018 10:28:59] File "threading.py", line 801, in __bootstrap_inner
[ERROR : Fri, 21, Sep 2018 10:28:59] File "testthread.py", line 83, in run
[ERROR : Fri, 21, Sep 2018 10:28:59] File "testthread.py", line 135, in runbutton
[ERROR : Fri, 21, Sep 2018 10:28:59] File "testthread.py", line 413, in sysc
[ERROR : Fri, 21, Sep 2018 10:28:59] UnicodeEncodeError: 'ascii' codec can't encode characters in position 0-4: ordinal not in range(128)
[WARNING : Fri, 21, Sep 2018 10:29:33] Stopping: Get Version
Any ideas to resolve the issue?
Thank you,
Hi @anatoli,
Thank you for the information.
I checked serial ports on the PC and found that unicode characters are included in the COM1 port description.
I experimentally *uninstalled* the COM1 device. Then the controller GUI works fine. So uninstalling the COM device could be a workaround.
But I hope the issue will be resolved by future update of the GUI software.
Thank you!
Hi @yfuji38
Typically, this error occurs when OS is not supported.
Supported version for latest Vivado version is Windows 10.0 Fall Creators update (version 1709), 10.0 Version 1803 (64-bit), English/Japanese. Refer link below, page 11:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug973-vivado-release-notes-install-license.pdf
Try SCUI in supported operating system.
Bhushan
Bhushan
Hi @bpatil,
Thanks for your reply.
I am using Windows 10 Pro version 1803. It is:
Just in case, I tried out again after,
- Uninstalled another Python application.
- Installed Vivado 2018.2
But there are the same errors in the log file...
Can you click on Layout and uncheck hide right pane? use a command like read Si570 MGT clock. Take a screencap including the right pane that is now unhidden.
Sure, attached below.
My system controller dosen't work with the same error.
1. OS Update
2. Firmware Update
3. UART Device driver version down
I have tried this, but it does not work.
Have you been resolved?
Please let me know if the issue is resolved.
Dear Xilinx engineer: I have the same problem, same error log . The OS is windows 7 64bit. Is this problem solved? Thanks a lot Peng
In my case, I did not find the cause, but it works on two out of six computers.
Try on another computer.
Hello @yfuji38 and other users on this thread,
We may found the root cause of this behaviour (thanks to @suguri ).
Please check @suguri 's reply in the similar forum topic: https://forums.xilinx.com/t5/Xilinx-Evaluation-Boards/zcu102-BoardUI-Error/m-p/1127099/highlight/true#M28597
Can you please check and see if this also helps in your case? Thanks in advance.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hi @anatoli,
Thank you!
Hello @yfuji38 ,
Thanks for letting us know. Glad to hear that you have managed to overcome this issue using the workaround that you've shared with us. This would be useful for other users with the same issue. Thanks once again.
As your issue is resolved now and if there are no further questions, can you please mark your last response as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions), so that the topic can be completed then?  We appreciate your help.
Have a nice day.
Kind Regards,
Anatoli Curran,
