ZCU111 in Vivado 2019.2
I have installed the latest version of Vivado 2019.2. Unfortunatly, i am unable to discover my board "ZCU111" in the Viavdo. Can any one suggest any help.
I have already downloded the package.
Amol
Re: ZCU111 in Vivado 2019.2
Hi amolb@iisc.ac.in ,
Please add the ZCU111 board files to Vivado directory and then try detecting the board in Vivado. For more information on adding board files refer this AR#72033 .
Hope this helps.
Deepak D N
Please Kudo and Accept as a Solution, if it helps.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
Hi amolb@iisc.ac.in
Do you mean you are not able to find the ZCU111 when you create the new project ?
It is there in Boards section
Yeah..
I am unable to detect the board when i am creating a new project.
Amol
Hi amolb@iisc.ac.in
It is there for me. Can you check if if you have board files for ZCU111 in the installation area
C:\Xilinx\Vivado\2019.2\data\boards\board_files\zcu111
We already tried this method and still we are not able to find our board.
Amol
Hope this helps.
Deepak D N
Deepak D N
Make sure your liscense is OK. There is a liscense Manager in Vivado that lets you check it. It has happened to me that I apply the liscence and some time after I had to do it again.
