zhiha
ZCU111 system controller UI bug during setting the SI570 MGT_CLK Frequencies
As you can see in the ug1271,the user_mgt_si570 clk is set by default 156.25MHz.
But when I use the system Controller UI to read the user_mgt_si570 clk , it shows that the clk frequency is 300MHz. And more weirdly is that I cannot use the system Controller UI to set the user_mgt_si570 clk to any other frequency, but can set the user_si570 clk.
I don't know the reason, thanks for your suggestion for the problem.
vatsalt
vatsalt
