08-16-2016 11:13 AM
I'm seeing very slow response in my ZC706-based application network operations.
To try and figure out what's going on I created a new project based on the base Zynq example and then created an SDK project using the LWIP echo example. I made no changes to the firmware or software -- everything is just as provided by Xilinx.
The application downloads and starts properly, but when I attempt to ping the board I see:
eric@FlashyBook 868> ping 192.168.1.10
PING 192.168.1.10 (192.168.1.10): 56 data bytes
64 bytes from 192.168.1.10: icmp_seq=1 ttl=255 time=1004.135 ms
64 bytes from 192.168.1.10: icmp_seq=2 ttl=255 time=0.210 ms
64 bytes from 192.168.1.10: icmp_seq=3 ttl=255 time=1003.004 ms
64 bytes from 192.168.1.10: icmp_seq=4 ttl=255 time=0.216 ms
64 bytes from 192.168.1.10: icmp_seq=5 ttl=255 time=1004.572 ms
64 bytes from 192.168.1.10: icmp_seq=6 ttl=255 time=0.231 ms
64 bytes from 192.168.1.10: icmp_seq=7 ttl=255 time=1001.487 ms
64 bytes from 192.168.1.10: icmp_seq=8 ttl=255 time=0.198 ms
64 bytes from 192.168.1.10: icmp_seq=9 ttl=255 time=1005.254 ms
64 bytes from 192.168.1.10: icmp_seq=10 ttl=255 time=0.252 ms
64 bytes from 192.168.1.10: icmp_seq=11 ttl=255 time=1003.902 ms
64 bytes from 192.168.1.10: icmp_seq=12 ttl=255 time=0.268 ms
64 bytes from 192.168.1.10: icmp_seq=13 ttl=255 time=1004.717 ms
64 bytes from 192.168.1.10: icmp_seq=14 ttl=255 time=0.275 ms
That seems weird.
It's as if the stack is only looking at the incoming packet queue once a second or so. The fact that I've seen no other reports of this on these pages leads me to believe that I've done something wrong. I just can't tell what.
Again, this is the example system and firmware with no changes. The network segment is completely quiet -- my laptop and the ZC706 are the only devices.
08-23-2016 10:58 AM
After some poking around in the ethernet driver I discovered that the problem is that the transmitter sometimes does not respond to the START request in emacps_sgsend():
/* Start transmit */
{ volatile int i; for (i = 0 ; i < 5 ; i++); } <<<<===== Add this line
XEmacPs_WriteReg((xemacpsif->emacps).Config.BaseAddress,
XEMACPS_NWCTRL_OFFSET,
(XEmacPs_ReadReg((xemacpsif->emacps).Config.BaseAddress,
XEMACPS_NWCTRL_OFFSET) | XEMACPS_NWCTRL_STARTTX_MASK));
I have discovered a workaround that appears to fix the problem. If I add the busy loop shown above the transmitter always appears to start as it should. I'm not sure if this is because some previous flush of the buffer descriptors needs a little time to complete or if there's some other issue in the GEM transmitter -- but the problem definitely appears when the busy loop is omitted and goes away when the busy loop is present.
