Anonymous
Not applicable
ZYNQ ZC 706 Board - Insertion loss of channel between the XC7Z045 FFG900 -2 SOC and HPC Connector
XC7Z045 FFG900 -2 Soc has many SerDes. Data rate can go up to 12.5Gbps per reference mannual. These serial links are connected FMC on the board. There are two FMC one LPC and another HPC.
We are planing to build a daughter card on these FMC which will use these serial links up to 12Gbps. We are looking for the insertion loss of channel between SOC and FMC. It will be nice if there is a plot including both SOC package and FMC connector.
Product brief of the board is avaliable at following link.  Page #2 has the board picture
http://www.xilinx.com/publications/prod_mktg/Zynq_ZC706_Prod_Brief.pdf
richsteeves
Were you able to get some additional information from Xilinx? I have a similar one for their VCU108 board (for 15gb/s operation).
For transceiver configuration the chanel behavior would be nice to know.
Best reagrds,
Richard
