arfayes
Zcu106 cannot boot with bsp prebuilt image
i use the pre-built files from the BSP of the zcu 106 : BOOT.bin and image.ub on BOOT partition of the sdcard.
the boot stuck and i have error loop.
all the traces are in the attached file.
i also generated an image but i cannot boot.
i tried 2019.1 and 2019.2 versions.
 i have ZCU106 REV 1.0
arfayes
the problem is due to system entropy i resolved my problem by adding the haveged to system startup.
add this line to petalinuxbsp.conf :
IMAGE_INSTALL_append = " haveged"
see https://www.xilinx.com/support/answers/72377.html
timothyv
Hello @arfayes
This may be an issue with the SODIMM of the ZCU106 board you possess. I have attached an AR that I believe may help.
AR#71961: https://www.xilinx.com/support/answers/71961.html
I hope this helps!
arfayes
