catzzang1
Zedboard current sense
I've seen some people use the oscilloscope and Zedboard's J21 pins to measure power.
However, I thought that the two pins of J21 were + and-, respectively, and connected the probes immediately, the board was turned off, and the spark occurred.
Can you tell me how to connect an oscilloscope probe to Zedbaord?
Thank you.
anatoli
Hello @catzzang1 ,
Have you checked this similar topic yet? This should help you with your query (hopefully):
https://forums.xilinx.com/t5/Xilinx-Evaluation-Boards/Zedboard-current-sense/td-p/679981
also
https://forums.xilinx.com/xlnx/board/crawl_message?board.id=XLNXBRD&message.id=9695
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
drjohnsmith
If I understand the case correct,
If one side of your scope was an earth connection, like the standard crock clip on a scope probe, , connecting that to a power supply results in a bang / spark / smoke escapes / dead chips.
You need to measure differential, using either a differential probe, or a pair of probes and subtract one voltage from the other.
