Visitor s224071
Zybo board using Xilinx ISE 14.7
For an university project I need to work with a Zybo Board. Which settings should I use when creating a new project in ISE 14.7? Is it possible to use it for programming this board or only Vivado is working?
Re: Zybo board using Xilinx ISE 14.7
Hi @s224071,
You can use in ISE as it supports zynq-7000. But I don't think you will have the board files available as for vivado on digilent website.
I would recommend you to use Vivado, as everything is ready on digilent website (link). It will be easier for you.
Kind Regards,
