Zynq UltraScale+ MPSoC for the Hardware Designer lab files
I am going through Zynq UltraScale+ MPSoC for the Hardware Designer courses from Xilinx Training Center. At the end of each course there is a lab. Each lab assumes to use prepared files for illustration. However there is no attached lab files, just a link to the guide. Am I missing something in how it is supposed to work? Are these lab files at the different directory I just don’t see?
Re: Zynq UltraScale+ MPSoC for the Hardware Designer lab files
Hi anna.raikin@fidus.com,
You can find all the labs files in the following link:
     https://www.xilinx.com/training/downloads.html
For the "Zynq UltraScale+ MPSoC for the Hardware Designer", here it is the link:
     https://www.xilinx.com/training/downloads.html#embdzuphw
Best regards,
Abdallah
Best regards,
Abdallah
Thank you. Perfect timing!
You are welcome!
Best regards,
Abdallah
I decided to add another question here since it is related to original topic.
The Xilinx courses (Embedded Systems design as an example) talk about new tools (Vitis in SDK Drive course and it include lab). But all labs are till 2019.1 which is still SDK. Are there newer versions?
As there is no 2019.2 lab for the "Embedded Systems Design" in the provided link, so you won't find it else where.
If you are interested in a Vitis lab you may want to check "Migrating to the Vitis Embedded Software Development IDE Workshop".
Best regards,
Abdallah
That's too bad.
Thank you.
