Participant kvkhekale
booting linux with sd card without rootfs.cpio in rootfs partition
Hello all,
I am trying to build linux kernel image through petalinux 2018.2.
According to UG1186, I made 2 partitions, BOOT and rootfs on the SD card, and copied BOOT.BIN and Image.ub on BOOT partition.
However, I didn't copy and extract rootfs.cpio file on the rootfs partition.
Still,
when I see the booting logs on the serial terminal, I can see the kernel booting and rootfile system directory inside the "/" directory
Just curious that where the root filesystem has come, when I havent copied the rootfs.cpio in rootfs directory.
Re: booting linux with sd card without rootfs.cpio in rootfs partition
Very likely your FIT image (image.ub) contains also rootfs ramdisk image and default config pointing to ramdisk boot. Check this AR https://www.xilinx.com/support/answers/68704.html.
