Observer lino89
clock input in spartan 3
i am using spartan 3 xcs400 tq144 starter kit for my design and i need to give clock input  to the design.
i am used to give the input by program but for this design i need to use the clock already available on the board.
pls help me to resove this problem
Re: clock input in spartan 3
Input buffers (IBUF, IBUFG, IBUFDS, IBUFGDS) pass external signals to the intrnal logic and output buffers (OBIF, OBUFDS) pass internal signals to external logic. So, yes if you assign an input buffer to the same pin that is connected to a clock signal and you have also assigned a compatible IOSTANDARD then the clock will be propagated to the internal logic.
you can use the on board clock for your purpose.
If you can give more details of the exact spartan3 kit you are using and what exactly your issue on using the
 clock present on the board.
We will be able to give you more suggestions.
Satish
Observer lino89
spartan 3 xcs400 - tq144
Observer lino89
to use on board clock which pin no: i have to assign
spartan 3 xcs400- tq144
Scholar pratham
I am not sure the board you are using but its from digilent then you should check this user guide
http://www.digilentinc.com/Data/Products/S3BOARD/S3BOARD_RM.pdf (Page no 35)
If the board is from different vendor you should be checking board user guide it should have the details about the board clock pin and all
-Pratham
Observer lino89
if i assign input pin any of the gclk will it use input from the on board clock
