Scholar mrbietola
debug application after boot from sd card is possible?
Hi, i made linux boot from SD-Card. Everything is right.
I reserved some memory to r5 processor in device tree as i want to debug a program. I then tried to connect SDK via JTAG but i had the RPI.APB AP transaction error.
Maybe is because my mode pins are on SD-CARD boot mode?
Can i debug an application via jtag after linux boot from SD-card?
If i stop the uboot before linux is started, i can debug the application even if the mode pins are on SD-CARD boot mode
Scholar mrbietola
Re: debug application after boot from sd card is possible?
I found that Debugger have problem if you don't specify cpuidle.off=1 in the bootargs  https://www.xilinx.com/support/answers/69143.html
Scholar mrbietola
