Visitor cto@qlt
error building TRD 2017.1 - Design Module 1 - Fetcher failure for URL - bad checksumm
I'm trying to build the "Zynq UltraScale MPSoC Base TRD 2017.1 - Design Module 1"
Unfortunately i encountered an error i don't know how to fix:
ERROR: protobuf-native-3.0.0-r0 do_fetch: Fetcher failure for URL: 'https://github.com/google/protobuf/archive/v3.0.0.tar.gz;downloadfilename=protobuf-3.0.0.tar.gz'. Checksum mismatch!
File: '/home/cto/TRD/rdf0421-zcu102-base-trd-2017-1/apu/petalinux_bsp/build/downloads/protobuf-3.0.0.tar.gz' has md5 checksum 41f2934b451a82115ccc4aa1f9b156f2 when d4f6ca65aadc6310b3872ee421e79fa6 was expected
File: '/home/cto/TRD/rdf0421-zcu102-base-trd-2017-1/apu/petalinux_bsp/build/downloads/protobuf-3.0.0.tar.gz' has sha256 checksum 44e36eee53a7bc8b88935b105c8e2773f6ae9f89e3f25e95f93c4bcac908bb98 when f5b3563f118f1d3d6e001705fa7082e8fc3bda50038ac3dff787650795734146 was expected
If this change is expected (e.g. you have upgraded to a new version without updating the checksums) then you can use these lines within the recipe:
SRC_URI[md5sum] = "41f2934b451a82115ccc4aa1f9b156f2"
SRC_URI[sha256sum] = "44e36eee53a7bc8b88935b105c8e2773f6ae9f89e3f25e95f93c4bcac908bb98"
Otherwise you should retry the download and/or check with upstream to determine if the file has become corrupted or otherwise unexpectedly modified.
ERROR: protobuf-native-3.0.0-r0 do_fetch: Fetcher failure for URL: 'https://github.com/google/protobuf/archive/v3.0.0.tar.gz;downloadfilename=protobuf-3.0.0.tar.gz'. Unable to fetch URL from any source.
ERROR: protobuf-native-3.0.0-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/cto/TRD/rdf0421-zcu102-base-trd-2017-1/apu/petalinux_bsp/build/tmp/work/x86_64-linux/protobuf-native/3.0.0-r0/temp/log.do_fetch.84832
ERROR: Task (/opt/pkg/petalinux/components/yocto/source/aarch64/layers/meta-virtualization/recipes-devtools/protobuf/protobuf-native_3.0.0.bb:do_fetch) failed with exit code '1'
Apparently the file to be downloaded has been modified, how can I resolve this issue now?
Should I tell the build process to ignore checksumm errors and hope for the best?
Where can i get the right file?
Or how should I proceed?
Visitor cto@qlt
Re: error building TRD 2017.1 - Design Module 1 - Fetcher failure for URL - bad checksumm
