genesys 2 board not showing up in Vivado HL 2016.1
I have recently purchased Genesys 2 board.
While going through project described at https://reference.digilentinc.com/genesys2/gsmbs, I find following errors while synthesizing:
ERROR: [Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xc7k325t'. Please run the Vivado License Manager for assistance in determining
which features and devices are licensed for your system.
I  installed Vivado  version 2016.1. The  design edition, and it does not show Genesys 2 board. So, I had to use Kintex 7 KC705 (which uses Kintex 7 device as on Genesys 2 board) platform.
I unstalled the software and reinstalled System Edition too. It also does not show Genesys 2 board.
The status of licenses shows node locked license for OEM_7K325T_DesignEd, which I suppose is validity of Genesys 2 board.
However, I installed Xilinx SDK ver 2014.4, and it runs the demo example file.
Can you help me how to use board and device in my Vivado FPGA project?
Dee
Re: genesys 2 board not showing up in Vivado HL 2016.1
Hi @deepakddn,
Please go through https://reference.digilentinc.com/vivado/boardfiles2015
and see if it helps.
Arpan
Hi @deepakddn,
Arpan
I downloaded the board details. I can now see the board in Vivado. However, the error still reamins same. I received a voucher for Vivado license, and I used lised license manager to copy the lic file for certification based license.
Dee
I found the problem as host mismatch. Creating a license with correct host solved the problem.
Dee
